Results 1 to 16 of 16
Thread: ECOTEC Poor Economy
    VS Executive S2 M35
    Dec 2011
    South Australia
    Default ECOTEC Poor Economy
    Hey, I recently purchsed a VT S2 and the economy is sh**. Its had a good service so, oil, plugs and lead, and all filters. It does about 17L per 100k's so its no good. It runs nicley but has poor economy even if my right foot is not having a stretch. Cheers...
    D22 St-r Navara
    Dec 2010
    perth
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Check for vacuum leak,oxygen sensor/s and their plugs(they r cheap,i replace them every year) wouldnt hurt if you clean the throttle body.If none of these suggestions helps,replace the whole fuel supply line with its regulator(the one that goes round the plenum and sits on top of the injectors).
    vr wagon
    Aug 2010
    vic
    Full service, new plugs, new leads, clean throttle body, clean maf,clean intake manifold,clean iac. New Fuel filter, new air filter and injector cleaner use good fuel and keep that foot un stretched and allow the computer to get out of it's loop of being driven hard. check all vac hoses. And exhaust restrictions.
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Basically to get started and keep it simple before going the whole 9 yards like CHA53R's post..
    The quickest easiest things would be to:
    1. Clean MAF sensor. <<< Search This Term
    2. Buy a bottle of injector cleaner and read the instructions on the bottle.
    3. Change fuel filter. <<< Search This Term. Sounds/looks a lot harder than it is.
    VS Stato l67
    Mar 2009
    Melb
    Agree with most of the above. Try changing where you buy the fuel from to. I find some fuel gets drastically worse economy than others
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Granny shifting, Not double clutching like you should.. Its always the culprit.
    There is no such thing as stupid questions, Only stupid people.
    Jul 2011
    Quote Originally Posted by TrikkBen View Post
    Replace the piston rings you fried.
    vr wagon
    Aug 2010
    vic
    Need NOS Harry! 2 of the big ones! Do a bit of googling when it comes to fuel filter. I read alot that people have trouble with the clips and break them! Think by memory it was push towards filter, press clips in and pull. Oh don't forget to pull fuel pump fuse and start her till she stalls.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    It's not abnormal for the car to run that type of economy. Unless your driving down the highway and that's the number you get.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Yeah my question is what's your driving highway or city? Even a grandpa in the Sydney CBD is gonna get something like that.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    VS Executive S2 M35
    Dec 2011
    South Australia
    Highway mainly, did the diognostic test and both my oxy sensors are cooked. But ill do all these things anyway just for good measure. this forum rocks, so much help. Ohhh and i did the trippy thing with the little LCD display showing all these digital readouts, rpm is my fav.
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    You might want to have a look at this then:
    VT-VX Hidden Trip Computer
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by F/INJ Suicide Machine View Post
    get lean cruise remapped in the memcal might save 0.5L though prob not worth it for the coin.
  15. #15
    Dec 2009
    As well as new O2 sensors grab a new air cleaner element. Are you sure the memcal is standard and hasn't been retuned?
  16. #16
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Also in my experience, fuel filer, air filter, o2 sensor, stay away from E10 (regardless of anyone's opinions about how good/bad it is. There is no question, you will get less mileage out of it). And don't rev beyond 2.5k, then let us know.
  1. VS Ecotec Poor Fuel Economy
    By primo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2011, 11:49 AM
  2. Poor Economy
    By jonmac in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-06-2011, 03:37 PM
  3. vt executive s1 poor fuel economy
    By runner69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2010, 10:45 AM
  4. VS ute stalling and poor fuel economy
    By finch21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2009, 09:43 AM
  5. poor fuel economy
    By VS1Tonner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 09:11 AM
