Results 1 to 18 of 18
Thread: fuel problem??? VT Calais
    1999 VT Calais
    Nov 2011
    wangaratta
    Default fuel problem??? VT Calais
    when i accelerate the car sounds as if its been starved of fuel or something? i put it flat and it just doesnt want to go it just splutters what could it be?
    '97 VS Commodore
    Dec 2011
    Bundaberg
    Check your air intake pipe and sensor because I had a similar problem and when I looked there was a split in the intake pipe. Thar is the only thing i can think of so if that is not the problem then I unfortunately can't help. But if it is, it is as simple as going to your local holden dealer part department and order another or take your chance to find one at the wreckers.
    1999 VT Calais
    Nov 2011
    wangaratta
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Quote Originally Posted by j-rad View Post
    okay ill try that, i was thinking the fuel filter?? possibly?
    Do it anyways. Easy enough job.
    Clean MAF sensor. << Search this term
    Injector Cleaner. << buy a bottle and read instructions
    Get your thumb on the throttle body and blip it to find intermittent vacuum leaks
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    1999 VT Calais
    Nov 2011
    wangaratta
    1999 VT Calais
    Nov 2011
    wangaratta
    i pulled the air box off and ran it straight through the maf sensor and there was no problem? could it be that the air filter is too thick and that its not getting enough air????
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    When was the last time you replaced the air filter?
    1999 VT Calais
    Nov 2011
    wangaratta
    well its a new car to me, the air filter doesnt look too bad?? maybe ill give it a blow out and see how it goes?
    1999 VT Calais
    Nov 2011
    wangaratta
    okay so i put in a high flow air filter, there are no disconnected vacuum hoses around the throttle body, i ran some injector cleaner through it. and its still doing it? any other thoughts on what it could be? the only other thing that i know that needs to be replaced is the fuel filter could that be the problem??
    1999 VT Calais
    Nov 2011
    wangaratta
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    If it's a 'new car' to you, best go through the usual service items, like fuel/air filter, spark plugs and more important, plug leads.
    Good luck!
    VE International 3.6L
    Jun 2011
    Gold Coast.
    Could well be the fuel filter. My Daughters VT was just like that a couple of years ago at 200,000K. Changed the filter and all fixed.
  15. #15
    1999 VT Calais
    Nov 2011
    wangaratta
    its got all new leads and plugs, the only thing my mechanic said on the last service was that the fuel filter is on its way out, its the only last think i can think of? although someones dad said it happened to one of his cars and the cat was blocked?? i doubt it but could it possibly be that??
  16. #16
    Jul 2011
    Blocked cat very expensive, fuel filter.. not so much lol
    Do the fuel filter broooo.
    Report back once you have!
  17. #17
    VT Wagon
    Dec 2011
    Penrith
    Good idea to check the pipe that runs from the EGR valve to the throttle body, easily overlooked and sucks in heaps of air when worn out. It makes the engine run lean and burns out brand new plugs in a day or two. Took me ages to find the culprit. After you fix the pipe install new spark plugs.
  18. #18
    1999 VT Calais
    Nov 2011
    wangaratta
    alright ill try those, the car is going into tomorrow for a full service ill get him to check it out!! (:
  1. VR Calais Fuel Problem
    By St3alth187 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2012, 08:35 AM
  2. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  3. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  4. vp calais fuel guage problem
    By vl_davo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2008, 02:10 PM
  5. Average fuel level problem on Vs calais
    By L31GH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2007, 05:59 PM
