Results 1 to 10 of 10
Thread: VX Calais Air Con Vent Problem
    VX Calais
    Mar 2011
    Default VX Calais Air Con Vent Problem
    Hey just a quick post hopefully someone can help as I'm about to return home across the Nullarbor in the heat.
    I have a 2000 Calais which has electronic air con controls and find when speed exceeds 100km/h (or when accelerating up a hill at or over this speed) the air will start coming out of the front demister vents instead of the face vents. I have to drop speeds to under 100ish to get the air to start coming out the face vents again.
    It still shows face vent on the display, changing the vent doesn't help.
    Is there anything I can check? Other than this the air con is working fine.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Start by checking the thin vacuum hose that should be connected at the rear of the intake manifold, see that is connected and is a good fit, also check the one way valve that is on the hose.
    MY RIDE
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    if its not the little vacuum hose on the manifold of the one way valve it'll be your actuator behind your center console. here is a how to
    how to replace air con actuator
    If in doubt......FLOOR IT!!!
    vt commodore sedan excutive
    Dec 2011
    monto
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by 2000vt View Post
    can anyone please tell me how to start a new thread
    Go back to the previous page and up near the top on the left hand side it says "Post a new thread", click on that.
    MY RIDE
    VX Calais
    Mar 2011
    thanks guys will check out tomorrow and let you know how i get on.
    cheers
    Brad.
    Dec 2011
    monto
    thanks having trouble with 2000 vt sedan changed and cleaned all usual suspects starting to think computer? Running out of ideas real quick what a xmas
    VX Calais
    Mar 2011
    I have checked the vacuum line from the manifold inlet and its connected fine, i can see the valve but don't know how to test it.
    Assuming this was OK (which I think it is as the system operates most of the time) I started taking apart the actuator as suggested above. I noticed quite a big hole in the front left part of the cover where the actuator is inside of (and the fan I assume) - Havent opened it yet but am about it.
    Would this be causing the problems?
    I also noticed whilst down there that some air is coming out of the footwell vent when the air is directed to face, so it isnt quite working correctly as I thought. (this is when parked)
    VX Calais
    Mar 2011
    This guy (vt commodore air con) seems to have the exact same problem as me and he replaced the actuator, so I will order one of these ASAP.
    Do you think its worth getting the cover replaced or just patch it up or leave it?
    Thanks for your help
    VX Calais
    Mar 2011
    Just an update got my actuator solenoid bank today and it has fixed the issue thanks guys.
    I had the fan/blower occasionally stop on high speed but have replaced the relay under the dash and that's fixed that.
    One last prob is the passenger vent is blowing warm/ambient temp air out quite fast, the drivers side is Woking fine. When I switch to foot both sides open and expel cool air, so not sure what's going on there, I don't think it's the actuator. Might just tape it up as a bodge job
    Holden sure build crap air con systems.
  1. AC vent problem VX
    By AustinPD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2010, 10:45 PM
  2. aircon/heater vent problem
    By madamd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2009, 11:09 PM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Strange VS Vent Problem..
    By Amishdan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2005, 10:15 AM
  5. VL demister vent problem
    By GH05T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-12-2005, 10:19 PM
