Results 1 to 7 of 7
Thread: Vt berlina tranmision????
    VT BERLINA LS1
    Dec 2011
    frankston
    Default Vt berlina tranmision????
    I have a vt berlina series 2 ls1.... Recently ive been havin issues in the morning when its cold, with the engine light coming up and gear box slamming into gears... Ive had a transmission service done as well and no problems?? Im only new to cars really and still learning. Is this a throttle sensor issue or..???
    AND ALSO WHEN I FINISH WORK OR GET IN IT LATER IN THE DAY ITS FINE AND THERE IS NO ISSUE???
    vr wagon
    Aug 2010
    vic
    Have you checked the registered code? if the engine light comes on it is registering fault codes. Do you know how to check them?
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Quote Originally Posted by CHA53R View Post
    Its an LS1. He will need a scanner tool or tech2 to check
    VT BERLINA LS1
    Dec 2011
    frankston
    yea mate ive had it at a auto trans place and they reset the codes but about 3 days later it happened again....so yeah thats where im stuck at the moment...
    cheers for the replay
    vr wagon
    Aug 2010
    vic
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Slamming into gears, particularly on the 1 -> 2 change is characteristic of a TPS issue. Having said that, if its an intermittent issue it may not log a fault code. Does the engine light stay on until you turn the engine off or does it go off by itself?
    VT BERLINA LS1
    Dec 2011
    frankston
    Hey mate sorry for the late replies the. Sometimes the light goes off and sometimes it stays on till I turn the engine off. I've asked numerous mechanics to have a look at it but say its fine. I hope it's a tps fault!!
  1. Vz berlina dash in vy berlina
    By luke641 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-09-2010, 06:16 PM
  2. Vz berlina dash in vy berlina
    By luke641 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-09-2010, 10:18 PM
  3. VT berlina to VX berlina Boot conversion
    By Salmon in forum Electrical Wiring / Questions
    Last Post: 08-05-2010, 04:46 PM
  4. Vx Berlina Grill On My Vt Berlina
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 07:47 PM
  5. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
