VX V8 will not crank over on the key. I am able to crank it and start it if I connect "Scan Tool " through the OBDII and use an alternative battery connected to the tool. I have been told that the BCM is probably u/s but have not had any other symptoms that others do. Tested all fuses and ok. Can not get "scan tool" to communicate to fault find. Any help appreciated.
