hey ive been looking everywhere online and cant find anything that helps the car has a knock but only when on running temp. and then when it goes to idle it just stalls i can see a bit of oil loss as well the knock is coming from the inlet manifold or the rockers but the lifters has been check and tested just had a service and waterpump and thermostat replaced.
PLEASE HELP
Checked the error codes?
Could be CAS.
it wont start up again until its cooled down if i drive it takes about 10 km or idle for about 30min then cuts out the fans come on and goes off like normal
