Results 1 to 11 of 11
Thread: New motor won't start
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Default New motor won't start
    Hey guys just put my new motor in and it turns cranks over fine but won't start I have a new memcal from mace to go with my cam and is there a certain way it has to be put in? and wold that be why it won't start if its in the wrong way cheers
    not yet
    Feb 2011
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the security light flashing when you try to start it? Are you using the same ECU?
    MY RIDE
    VT V6 Berlina
    Apr 2011
    Maroochydore
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Why don't you respond to the questions that have been asked?
    MY RIDE
    VT V6 Berlina
    Apr 2011
    Maroochydore
    sry didn't see the question wheres the security light and yea using the same ECU just put new mescal in it
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by vtv6 View Post
    The security light is in the mode switch (trip computer).
    MY RIDE
    VT V6 Berlina
    Apr 2011
    Maroochydore
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    46 is Crank Angle Sensor (engine will not start). Since you have replaced the CAS it might be a bad connection or the DFI module.
    MY RIDE
    WL Caprice
    Mar 2011
    Here you go - it relates to a VX question, but a simple search gives this:
    help with code 46
    Good luck!!!
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Cool thanks guys will check it out in the morning
  1. VLT Start motor on the way out?
    By calais_SC6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-06-2011, 06:50 PM
  2. changed motor & wont start
    By naked racer in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2011, 02:59 PM
  3. VT wont start ??? starter motor ??
    By Miss L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 08:04 PM
  4. Motor turns over but wont start...
    By Stellaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 09:36 PM
  5. vn motor won't start
    By js1978 in forum Electrical Wiring / Questions
    Last Post: 31-08-2005, 09:26 PM
