Results 1 to 5 of 5
Thread: Vt 195i slugish when you first start it of the mark even when warmed up ?
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    Question Vt 195i slugish when you first start it of the mark even when warmed up ?
    Hi guys. Vt 195i why is it slugish of the mark when you first start it even when the engine is warmed up its auto. If you let it run for about 5 -10 seconds it takes of fine but if you start it and put it strait in gear its a slug untill it runs for abit. Could it be a fuel pressure problem or ? Thanks for the help cheers.
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    It sounds like for some reason your trans is going into limp home mode for a short time. Check out item 24 of 4L60 common problems and see if the symptoms are familiar:
    24. Car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
    Jul 2011
    NSW
    Yeah thanks mate for the info i will check that. If it was eletrical wouldent it run engine light on that thanks heaps Travis
    Jul 2011
    NSW
    Becouse it only does it when you first start it even when the engine is warmed up it is slugish of the mark but after about 5 or 10 seconds it runs good thanks.
    Jul 2011
    NSW
    Any other info on what it could be cheers.
  1. vr transmission running odd when warmed up
    By slepar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 05:53 PM
  2. vp misses when warmed up
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2010, 11:50 AM
  3. how much oil capacity is there between the full mark and low mark on a vs ecotec?
    By old mate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2010, 08:33 PM
  4. VL Calais no start when warmed up
    By Degeko in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-03-2010, 05:14 PM
  5. hard to start when its warmed up
    By MontieVHSL/E in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2006, 10:53 AM
