Having trouble with VT commodore Acclaim. When driving the dashis showing warning lights for ABS, trac off, Air bags and oil lights and the temp gauge is not working. After a bit they turn off. Anyone know what the problem could be?
Such is life
that's how mine started, eventually got worse until air con stopped working etc, ended up being the abs module.
+1 for abs module.
There's a guy offering a reco service through ebay for $175. You'd have to put up with not having a car for however long it takes though.Click here for eBay ad
Other than that they seem to be around the $270 area.
Would it be worth getting Holden to pull the codes for fifty bucks, as in would this type of issue have logged any fault codes?
Not asking the OP, just throwing it out to the gurus.
pretty much guaranteed to be the abs module, its so common its not funny, i would just save the $50 instead of getting codes checked, get a abs module off ebay, 99.9% sure that will fix it, and if it doesnt, just sell the new module, either way save your $50
just wanting to know can we still drive it with these problem untill i can get it fixed.
Such is life
Yes you can,BUT,incase of accident (if insured) you wont be covered,avoid sudden braking,wheels will lock up,also air bags might not deploy.
