have a vt at my house
when u put the key in all the lights come up then turn it ti try and start sometimes it will turn over maby half to one turn others nothing at all when it dose turn over it will fire then stop
any idears would be good thanks
the battery in your key is dying
get a new key or resolder in the battery
mine is funny in that the car will fire on the old key if its cold but once its hot... you need the new key
thanks for putting this up my brothers car does the same thing i should be able to rectify it now
Also check to make sure the Remote is contacting the metal ring around the ignition barrel
Exactly. If the key fob isn't contacting the slip key reader around the barrel, then these symptoms you mention will occur. Mine did it and I had to pull both keys apart ond fix the connections on the fob and slide it out slightly. Now one key is doing the same thing again.
