Just seeing if I need a regas on my VX. The air cond temp fluctuates between 10-13 degrees which seems a bit high.
I had a old Corolla which used to sit at around 3-5 degrees!
Are there any other common problems with the VX air cond system, such as TX valve, compressor etc?
Or should I just get a regas, fill it with the dye and check later?
I would just get a regas and go from there but those temperatures are quite high. Mine sits on around 3-5 degrees.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
They do have a habit of lunching compressors. Just re-gas with dye and go from there. You can buy a new compressor off eBay for $275.
Yeah I'll get the gas pressures checked and dye added and go from there.
My old VS ute had temps at the vents of around 3-6 degrees so it is definitely a bit high on this.
Will get it checked out and go from there. Hopefully regassing it doesnt put extra pressure on the rest of the air cond system.
Edit, the compressor on the ls1 is about $500![]()
Make sure you are not getting any hot air bleeding through from the heater because the tap is not sealing off or perhaps the vent door not shutting fully home. I have fitted a low pressure tap in the hot side of the heater hose from the engine and turn it off during the hot weather to prevent any possibility of heat from the heater core contaminating the cooled air from the evaporator.
