Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By lufkin
Thread: How to tell if my engine is gone.
    2000 VT S2 Olympic Ediiion
    Feb 2010
    Default How to tell if my engine is gone.
    Hi,
    I have an ecotec V6 engine. For the past 3 days upon start up i was greeted with a large grinding noise fromthe engine bay everytime I started it. But after start up it dissapeared. Last night it happened again quite
    loud & now the engine wont start. Im pretty sure its no electrical fault. Electrical wants to start the car but
    the engine just putts a couple of times and then wont start. I have had a new air compressor, drier & tx
    valve fitted & system gassed recently & this grinding noise didnt start happening till after the ac was done.
    Any suggestions would be great. I will propably get a tow to my house or a mechanic today depending on
    the problem but im with nrma r/s/a so hopefully they will know what it may be.
    Thanks for reading guys.
    You can lead a fool to wisdom but you can't make him think.
    Tuned VX SS
    Jun 2010
    loud grinding noise? to many possibilities to hazard at a guess. Hopefully you havnt done a big end bearing.
    does the grinding sound like its in the engine block or something else in the engine bay?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's is hard to say without hearing it but it might only be a bearing in one of the belt pulleys and the starting problem could be a separate issue.
    MY RIDE
    Feb 2010
    Yeah unfortunatley as the sound doesent last long every time I couldnt get out of the car quick enough to look where it was coming from thanks for your help guys ill hit back to base with what the nrma mechanic has to say hopefully its something i can repair myself. From a guess i would say it was coming from near the ac compressor but not sure it would be that just i head the sound come from that bottom right side of the engine bay. I assumed the drive belt everytime i got out and looked it was fine.
    VX Executive S2
    May 2006
    Frankston South Vic
    possibly starter motor pinion not disengaging
    also idler pulley is very common
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I would remove the drive belt and try a start. This will eliminate all the moving parts that could be causing the noise. It's not going to hurt to do a short run with the belt off.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Ill guess at the starter. Thats what could cause a grinding sound on the left side.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Yeah starter motor mate!
    Grinding noise is the the pinion not disengaging from the flywheel and it has probably shit itself hence why it won't start
    Should be able to pick a reco one up for like $150 approx
    Feb 2010
    Thanks guys will check it out by the way if the pinion has crapped out is it a visible fault?
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Feb 2010
    Starter bosch $209.00 brand new.
    VY SS
    Jun 2006
    Albany
    Quote Originally Posted by dope505069 View Post
    you will need to pull the starter motor out, if you can spin the pinion easily in both directions it will be stuffed
    Feb 2010
    Turned out to be the fuel pump. The grinding noise was the ac/compressor im gonna have to take it back & hit the guy up. Thanks for your help.
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
