Results 1 to 8 of 8
Thread: VX Engine start up Vibrations
    2000 VX Berlina Sedan
    Jun 2011
    Newcastle
    Default VX Engine start up Vibrations
    Hey guys,
    Started the VX V6 this morning and noticed very bad vibration/shake from the engine for the first 30 seconds after turning it over, only did this from a cold start, warm start was no vibration at all.
    Im not sure if its the mounts, fuel, oil or something else.
    I use
    Catrol Mag 15-40
    Shell 95 Unleaded (98 every 3rd or 4th fill)
    Cant see anything wrong with the mounts just by looking but they they have never been replaced before(180,000km).
    Any suggestions would be great.
    Nate
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    could be the fuel pump getting ready to go.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VX EXEC 3.8's Avatar
    VX EXEC 3.8 is offline Police Spec VX Executive
    VX Executive 3.8 9C1 pack
    Mar 2010
    NSW
    Does the fuel pump have a noticeably loud squeel when its running?
    They seem to become noisy before they die.
    Jun 2011
    Newcastle
    haven't noticed any new noises coming from the engine bay, everything seems the same except for the vibrations, basically the whole car shakes for around 30 seconds when starting cold unless I give it some revs.
    Jun 2011
    Newcastle
    Could it be that some of the spark plugs arn't firing? I'm out of idea at this point and hope it isn't the fuel pump.
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    I'd look at the usual stuff.
    Even if none of these are the problem its good maintenance.
    Check and/or replace plugs and leads.
    Change fuel filter.
    Clean MAF sensor.
    Clean throttlebody and IAC <<< I'd strongly recommend doing this if your car is high km's or goes long intervals between services.
    The last 3 will cost you jack all to buy the products necessary so get to it!
    Jun 2011
    Newcastle
    Ok started it this morning with no problems, I will still give those parts a good clean and change the plugs, have to change the fuel line too, cracked the connector to the filter
    Jun 2011
    Newcastle
    I found that some sparkplugs wern't firing, changed them all up and 150% improvement, the plugs that came out looked factory but not sure.
  1. Sudden vibrations + engine uneven, help!
    By Stressball in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 08:10 PM
  2. Vibrations under 1000 RPM, rattling noise from engine
    By Steery in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2008, 03:21 PM
  3. Engine: Vibrations becoming noticeable.
    By VSIIISU in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2008, 10:27 PM
  4. Vibrations - Rear engine mount
    By don0xer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2006, 09:19 AM
  5. VS engine fanruns and no start
    By Jason in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 07:18 PM
