Results 1 to 5 of 5
Thread: Idling problem
    VT V6 Berlina
    Apr 2011
    Maroochydore
    Default Idling problem
    Hey guys can't find out the problem with my new engine hoping someone on here could shed some light.
    when it idles it is a bit rough it has a comp stage 2 cam in it so I would imagine that would have something to do with it but it goes up and down a little bit in the revs and when you goto drive it stalls when you come into a corner or take your foot of the accelerator to slow down the revs drop fast and stalls, I have pinned the throttle cable open with that black clamp on the cable near the TB and it idles just under 1500rpm and it drives like it should until I stop the car and start it up again I have to unpin the cable and pin it back again. Thinking about getting a custom kalmaker tune because the mechanic said it seams like the ECU is not getting a return signal from the TPS or something
    Thanks Guys
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    when it does idle does it surge then drop for abit then go back up?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VT V6 Berlina
    Apr 2011
    Maroochydore
    vn_v6's Avatar
    Aug 2009
    victoria
    thats your computer not coping with the cam, i know of somone with a supercharged 6 and it does the same. you need a tune.
    VT V6 Berlina
    Apr 2011
    Maroochydore
    I got Steve from MACE to do me a memcal for the cam though.... could it be a bad tune and just need to send it back to MACE or would I be better off getting a Kalmaker tune
  1. Idling problem
    By chaddy83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2011, 11:11 AM
  2. 304 Idling problem
    By VS CLUBSPORT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 02:57 PM
  3. idling problem
    By vy ss 350 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-01-2010, 07:37 PM
  4. idling problem?? how do i fix it!
    By entcrt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2009, 07:11 PM
  5. VS Idling problem
    By SMIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 09:13 PM
