Results 1 to 7 of 7
Thread: oil in radiator
    vt commodore
    Jan 2012
    australia
    Default oil in radiator
    traces of oil in radiator, no trace of water in engine oil and transmission oil. any ideas?
    VT HSV XU6
    Jul 2011
    ACT
    hey mate i had the same problem was in the water but no where else we changed the Radiator and it did a couple of flushes and seems to have fixed it. But a few questions is it the V6 ecotec engine or a V8? if its the V6 cheapest thing u can do is a new radiator, but if it dosnt fix it then it looks like it may be a f@#ked manifold gasket really dont think its the head Gaskets because the oil and water jackets arnt really close so it may be the vally or manifold but do the radiator first b4 u jump straight in to pulling the motor apart and spending around $2000 that might not fix it also is it motor oil or Trans fluid?
    Cheers, Daniel
    VX Executive
    Feb 2008
    If you have access to a trained mechanic, take a look at the transmission cooling lines headed into the radiator. check your transmission oil as well. Usually doing a complete flush will solve the issue, and its an alternative instead of tearing up the engine
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    its either a trans fluid leak, or a busted inlet manifold gasket.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Contaminated coolant - the slightest drop of oil on the vessel that was used to fill up the radiator etc. will cause some specks. Had exact same issue on the VB; flushed coolant, filled it up, oil slick; remembered my hands were greasy from the just-done oil change. Monitor for any strange noises, billowing clouds of white smoke; check the radiator cap with the engine warm and running - no bubbles=ok head gasket.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Not 'rocket science', if it's a reddish colour it's auto trans oil. If it's grey/black, it's engine oil, more than likely leaking through the inlet manifold gasket into the water jacket,.......... common occurence unfortunately.
    vt commodore
    Jan 2012
    australia
    its a v6 ecotec and thanks for your feedback ill keep you posted
LinkBacks (?)
  1. Rb25/30 Radiator hose for vl radiator.
    By vl_2010 in forum Straight 6 Development And Modification
    Last Post: 23-06-2011, 11:46 PM
  2. should external trans radiator be inline with radiator compartment
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 10:50 AM
  3. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
