Results 1 to 11 of 11
Thread: ls1 engine light
    VT SS 5.7
    Mar 2005
    Goulburn
    Default ls1 engine light
    Been noticing for the past 2 weeks on a cold start up the vt ss throws up the engime light, turn the key off then back on and no light everythings fine.
    And now lastnight driving home i went over afew bumps in the road and now the light is on and staying on. the car still has all its performance doesnt seem to be lacking . idel`s fine. just not sure what else to look at while im waiting for my scanner to show up.
    I did try swaping over my TPS and no diffrence the light stays there after start up
    (Mods)(twin 2 1/2inch xforce system, pacemaker hi-flow cats,pacemaker tri-Y.)
    Only thought i had was the o2 sensors
    Real cars don't power the front wheels, they lift them
    vt ss s2 6spd
    Sep 2008
    VT SS 5.7
    Mar 2005
    Goulburn
    Would it be better to just replace them or get a tune done
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Take both batt terminals off,meantime check all your sensor connections.after re-connection,if same read code.
    VX Calais
    Jun 2008
    SA
    it's more than likely either the o2 sensors playing up, or the oil pressure sender...mine did exactly what you described and it turned out to be the oil pressure sender. Cost about $70 for a non genuine one or up to $150-200 genuine from a dealer plus install/code clearing
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    There is a trick in getting codes from ls1. Once you get cable I will tell you or see my post.
    VT SS 5.7
    Mar 2005
    Goulburn
    i just got Autel MaxiDiag US703 ODBII/EOBD (Vehicle) Diagnostic Code Tool (Australia) | eBay with the help and advice from DLFHUB666 that should do the trick
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by madsav View Post
    Let us know how it goes because most of these types of scan tools won't read codes on an LS1.
    MY RIDE
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by accentstencil View Post
    I have an us703 an it will read an delete DTC's(plus a whole lot of other stuff) have used it on my vx ss a vy clubsport an my misses 09 jg cruze.Edit: Was curious if it would work on the cruze an it did i haven't actually needed it for codes on this car yet.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by DLFHUB666 View Post
    Good to know. I bought a similar type of scan tool quite a few years ago and it reads live data but not codes.
    OBD II 2 CAN Car Trouble Code Reader Scanner Tool DTC | eBay. I paid a fair bit more at the time.
    MY RIDE
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Yes, It can be tricky buying scan tools but soop had a us703 an said it worked so i got one.The us703 is also very easy to use, never having owned one.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
