Hi all,
My VT series 1 calais had a low speed altercation with a roundabout sometime ago, air bags weren't deployed.
Since I have had several issues, and I'm hoping to glean some ideas about how to rectify them...
Issue 1:
Loss of steering wheel stereo controls, loss of horn, and airbag warning light illuminated
Thoughts?
Issue 2:
AC or fan won't blow out the dash vents, but floor and screen are fine
Is this likely to be an AC actuator issue?
Issue 3:
Outside temp gauge not working (stuck on 22deg)
likely cause?
All issues began at same time, after the roundabout incident... All fuses check out fine....
Any thoughts greatly appreciated. Cheers guys, Harry
Issue 1 clock spring to be replaced for the horn and steering wheel controls and air bag light To work Again
Issue 2 check vacume lines to the climate control sounds like one of the lines might of come off or dud vacume actuator
Issue 3 out side temp look on the front left of the air con condenser at the bottom and see if the sensor is damage or wiring pulled out take it out and give it a clean if nothing works replace it
I thought clock spring as well but it is most unusual to have the 3 ribbons in the clock spring go at once.
Also check vacuum hose at the rear of the intake manifold.
MY RIDE
