Results 1 to 2 of 2
Thread: VT Calais Headlight problems
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    Default VT Calais Headlight problems
    Hi all
    I have a 1997 VT Calais
    My problem is that when I have low beam lights on - I switch to High Beam and the RHS lights switch off (or very dull). The same occurs when I have low beams on and switch on Fogs (RHS lights switch off or very dull)....
    *Low beams (and parkers) by themself work fine.
    *Parkers and Fogs by themself work fine.
    See a previous thread, not replied to, with the same problem (perhaps explained a little better):
    Vt Calais 98 model headlight issue/
    * I have checked all of the relays & swapped etc
    * I have checked / cleaned terminals at rear of headlights
    * I have checked / cleaned earth connections (at battery, inside front RHS inner guard wall, RHS strut tower near the fuse box)
    * I have checked wiring (as best as possible) from fuse box / relays to each headlight for shorts, etc.
    * All globes seem to be working.....
    Has anyone else had this or heard of this??
    ANY Help / suggestions would be greatly appreciated!
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    Problem fixed all.....
    Blown fuse in relay / fuse box of Engine bay....so fricken simple after all that!
    Thanks to Bass308!
  1. Help Please! Headlight problems...
    By LOYAL in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2010, 06:53 PM
  2. Headlight Problems
    By VTeezer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2008, 09:37 PM
  3. headlight problems
    By HVXII in forum Electrical Wiring / Questions
    Last Post: 03-07-2008, 04:47 PM
  4. vl Headlight Problems
    By anothercarnut in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-11-2007, 08:37 PM
  5. VL headlight problems
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2005, 07:57 PM
