Results 1 to 17 of 17
Thread: Antenna clicking
    VT Berlina
    Jan 2012
    Wonga Park, Victoria
    Default Antenna clicking
    Whenever I turn the radio on/off, the automated antenna erects/retracts and makes a clicking sound at the end of the process. My best guess is the motor is winding the antenna more than it should and the clicking sound is teeth jumping? I haven't a clue how to fix that :/
    Would it be worth just disabling the motor, since I'm looking at getting a new head unit, that might render the feature useless? Not to keen on that though.
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    vx s-pac
    Nov 2010
    victoria
    Hey guys, I also have the same problem with my vx. How do you disalble it?
    vn executive s2 v6
    Jun 2008
    more like how do you Fix it is what i want to know
    to disable remove the inner guard (plastic rivets and screws easy as) and disconect the plug. that should do it.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The mast needs replacing. It will cost around $30 and is not that difficult to replace.
    vt mast | eBay
    MY RIDE
    VX Berlina II
    Sep 2011
    Quote Originally Posted by accentstencil View Post
    vt mast | eBay
    mine makes a clicking noise what comes from the right hand side of the steering wheel in the dash, thought it must of been normal but guess not, seeing the aeriel is on the left hand side i thought it would click over there but nope, guess i need a new mast too then? doesnt annoy me too much though, or could it cause more damage?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Ever since I got the VY, five years (110,000 k's) ago, it's done this too. When it gets to the fully up/fully down position it gives about four little clicks. Mast isn't bent and doesn't have any problems. Doesn't worry me.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I put up with the clicking for about a year and finally replaced the mast, I must say it is a lot better without the clicks.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by daNc View Post
    Yours don't sound like a mast problem, the clicking could be coming from the BCM.
    MY RIDE
    VX Berlina II
    Sep 2011
    ah is that bad? how would i fix this then?
    EDIT: used to hear it every time i would press the up or down button for the antenna on the stock head unit, and also when turning the car off once its finished going down all the way you hear an even louder click what comes from the direction the antenna actually is, not on the right hand side of steering wheel, so maybe i have both problems?
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    My VT Calais used to do that. I thought it gave it character. It didn't bother me.
    Quote Originally Posted by Dv8eD View Post
    Does anyone know how to pop the reverse sensor back into its spot without removing the rear bumper?
    Quote Originally Posted by Rufys View Post
    1. Remove the rest of the car from the rear bumper. Pop the sensor back into place. Re-attach the car to the bumper. Personally, I reckon it would be easier to remove the rear bumper.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I don't know if it's bad or not but the BCM does control the power antenna.
    MY RIDE
    VT Berlina
    Jan 2012
    It's not a very pleasant sound IMO, sounds like something is about to break. I can deal with it, but if I can fix it I will.
    I noticed part of the telescopic rod wasn't extending, at least it appears as such. So it could be grit or something stuck in the antenna, instead of the motor over winding, I dunno.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    A while ago my antenna stopped retracting all the way, by about 3-4 inches. It was a VERY SLIGHT bend in the mast, after carefully straightening it, it's fine, but still clicks.
  15. #15
    VT Berlina
    Jan 2012
  16. #16
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by GIJoel View Post
    accentstencil, might I ask where you got your replacement from?
    I got mine on ebay but I noticed some at AutoPro the other day for around $49 I think. Cheaper on ebay, as per the link I post earlier.
    MY RIDE
  17. #17
    VT Berlina
    Jan 2012
    Late Update; My mate erected the antenna and with a cloth greased it up, de-erected the mast and repeated the process a few times. No more antenna clicking!
    My best guess is the motor was struggling to push up a section of the mast which may have been jammed. Hope that helps.
  1. Electric Antenna Clicking
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2010, 12:40 PM
  2. why is this clicking?
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2010, 08:52 AM
  3. Connecting antenna wire to radio antenna
    By Denno in forum Electrical Wiring / Questions
    Last Post: 02-04-2010, 05:23 PM
  4. Clicking under dash
    By zedbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2008, 09:12 PM
  5. Intermittent clicking from under car
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-02-2006, 09:15 AM
Tags for this Thread
