hey guys my car is a series 1 VT 99 model, and even on fe2 springs it looks like i have a bit of camber, and i want to lower it soon quite low.
im thinking about getting a rear cradle with the camber toe adjustment on it.
question which rear cradles will fit my car, like from which model cars?
if i got a vy/vz cradle will my diff/shocks/control arms/bushes and brakes still bolt up fine?
or should just get a rear 2 point camber kit?
cheers dan.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
The VXII-VZ cradles have toe-links which help to stop scrubbing but if you go further than "lows" then you will still (in almost all cases) need a camber kit.
Yes everything will bolt up fine from your car to ANY VXII-VZ sedan cradle.
Unless you can get the change over done on the cheap or are doing it yourself, I'd say get a camber kit. 4-Points get a lot of praise but on the other hand some people complain that they ruin your CV's and diff.
Use that search button and you will have no problem finding a million discussions on the subject.
Just make sure the cradle you get is from a sedan or else you will find that you have wasted your time when you go to bolt up your shocks. You will need to put your VT diff into the old cradle OR get a VX-VY tail shaft to suit the bolt pattern on the new diff.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
