Results 1 to 5 of 5
Thread: Vx V6 commodore intermittent miss in engine
    vx executive s2
    Jan 2012
    ballarat
    Default Vx V6 commodore intermittent miss in engine
    hi all just after a bit of help my 01 vx has developed a intermittent miss, on startup coughs and splutters for 15 seconds then clears up but when put under load will also hesitate and miss then you hear a loud cracking sound, then it clears itself up and runs fine with the occasional miss and till you stop the engine for a while and start again.
    i have so far replaced leads, plugs, fuel filter which was chockers full of crap blew the fuel lines out, cleand maf,idle,and tps, rechecked plug gap, ran injector cleaner through it but my senses are still saying injectors any ideas?
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    vx executive s2
    Jan 2012
    ballarat
    Jul 2011
    First result on search for "ecotec fuel pressure" says
    V6 ecotec (VS) 3 bar (43.5 psi)
    V6 ecotec (VT-VY) 3.5 bar (50 psi)
    If its within a few psi of that then its not your pump or regulator
    vx executive s2
    Jan 2012
    ballarat
    thanks ill give it a shot
  1. VE SSV engine miss
    By wez84 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-03-2011, 06:25 PM
  2. V6 Intermittent miss
    By VR38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2009, 02:55 PM
  3. Intermittent 5 Litre engine miss
    By vsv8berlinawag in forum Electrical Wiring / Questions
    Last Post: 03-01-2009, 08:45 PM
  4. intermittent miss at idle help
    By danny1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2008, 09:47 PM
  5. Intermittent miss on VP V8 with engine light flickering
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 08:53 PM
