Results 1 to 13 of 13
Thread: VT V6 Idler pulley confusion.
    VT Exect.wagon
    Feb 2008
    Default VT V6 Idler pulley confusion.
    My 1998 VT V6 idler pulley was making a racket. I check out what's available on Ebay and the new pulleys on offer are a different size than mine.
    Checked with Repco's computer and it says that the pulleys for the VT are...
    Pulley #1 76 17 31
    Pulley #2 is 90 17 30.
    And both off Repco's pulleys are flat metal and have no grooves. One of mine has grooves.Does anyone know the correct size of these pulleys and will no grooves make any difference?
    Also which size is the #1 top pulley -I think my pulleys locations may be reversed.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The top one is the tensioner pulley. It does matter if it has grooves. You don't need to know the sizes to get the correct pulley.
    Print out the diagram below and go to Holden and tell them which one you want, the cost of these is comparable to Repco anyway.
    Attached Thumbnails Attached Thumbnails VT V6 Idler pulley confusion.-drive-belt.jpg
    MY RIDE
    VT Exect.wagon
    Feb 2008
    Yeah thanks for the reply Accent but I am talking about the two idler pulleys that are on top of each other on the passenger side of the motor.
    My #1 (top) pulley is flat and is 82mm.The #2 (lower) is 6 ribbed or grooved and is 76 mm From what I have been reading online there is just
    something not right with this from what I have been reading in the Ebay ads.
    VT Exect.wagon
    Feb 2008
    Incidentally Accent good idea re the Holden dealer, unfortunately it's 5 hour round trip to the nearest one.
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by jindy View Post
    What I just changed the top pulley on my neighbors vx and I am more than 100% sure that the top one is ribbed and smaller than the one underneath it which isn't ribbed.
    Thats strange, take a pic if u can.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    The grooved side of the drive belt MUST run in corresponding grooved pulleys. The flat back of the belt must run against flat pulleys.
    vs commodore
    Oct 2009
    Tamworth NSW
    The top idler pulley should be ribbed,the lower idler pulley should be smooth. If you have the metal type pulleys instead of the plastic type, you can just replace the bearings in these pulleys when they wear out.All I needed was a set of snapring/circlip pliers. I paid around $5 each for new bearings for my 2 idler pulleys from the local bearing place.. The metal type tensioner pulley also has a replaceable bearing and only costs around the same as the others.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Lol I went to repco to get a new one aswell and I told then which one I needed. The idiot behind the counter brought out 3 pulleys and asked me if it is any of them... And it wasn't, so he said he dowsnt know what I'm after then. Obviously it was a waste of time even going there. I then went to an automotive bearing place and they got me the right one straight away
    Moral of the story... Don't go to repco unless you know what you need..
    VT Exect.wagon
    Feb 2008
    Thanks for all the good info folks. I actually nailed down the correct one at Repco .The Repco top #1 idler [U ]groove[/U] pulley is RPU 530. 76 mm.I would have
    done the replace the bearings thing as you suggest Brett but there ain't no bearing shop within 180 k's of where I live and I needed the car fixed pronto.
    Thanks again all.
    VS V6 Acclaim
    Jul 2008
    Sorry Jindy, only just saw the thread.
    Mack's Tyre and Auto in Cooma keep them in stock.
    If you have a look the bearings in them are replaceable. Once pressed out and cleaned, you can easily read the bearing number and pickup all 3 bearings next time you go to Canbrah from 'consolidated bearings'(i think).
    The bearing are $30 versus $80-100 for the full pulley set. Hell easy to do.
    Those bearings have a habit of going on long trips so its nice to carry spares when you live in the bush.
    VT Exect.wagon
    Feb 2008
    Yeah thanks BowTie re 'consolidated bearings. Good idea to keep some spares in the car too.
    VS V6 Acclaim
    Jul 2008
    VT V6 Berlina
    Apr 2011
    Maroochydore
    I know that they changed the pulley that is near he aircon to a bigger pulley on the series II with meant you need a bigger belt
  1. Idler Pulley Q
    By raovq in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2010, 06:06 PM
  2. Pulley idler changes?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 06:52 PM
  3. vt Idler Pulley
    By sheapard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2007, 06:07 PM
  4. idler pulley arm
    By daron in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 10:48 PM
  5. Idler Pulley
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2006, 09:29 PM
