Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By SUSVS
  • 1 Post By Brett_jjj
Thread: Vx ss transmission slip
    vx ss series ||
    Dec 2011
    Wanneroo
    Default Vx ss transmission slip
    I bought a vx ss roughly 2 months ago it's a 4 speed auto
    Just tonight my gearbox started whinnying and will not change out of first gear until it hits about 3500 rpm
    All the others are fine
    I don't know what the problem is
    And suggestions and help will be well appreciated
    Thank you
    VR Calais
    Mar 2011
    Plumpton
    Its a normal issue, u need a rebuild
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VT feature car, WRX STI WAGON
    Aug 2006
    vx ss series ||
    Dec 2011
    Wanneroo
    Commodore M6
    Jul 2010
    East Coast
    isn't the standard proceedure to check fluids and pray
    and if that fails...
    open the wallet for a new trannie
    VR Calais
    Mar 2011
    Plumpton
    Back when I was in the market for a rebuild I was lookin at 1500 to 2200 depending what went in it
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    By all means try changing the fluid but it sounds like it's too late.
    If your keeping the car then rebuild it and have it done properly. You will be so happy you spent the money.
    If your planning on selling it soon then just slap a used one in there and forget about it.
    vx ss series ||
    Dec 2011
    Wanneroo
    Yeah a little late for it haha
    May need to invest in something a little stronger
    Would it be worth getting this one rebuilt with high stall and trans cooler
    Its done 134000 or just new one with trans cooler?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    First step before you spend big money would be to change the TPS (throttle position sensor) - cheap and quick to do. Especially if you are getting harsh shifts when the box does decide to shift.
    Next step would be to change the 1->2 shift solenoid in the box when you are replacing the fluid/filter. You can also check to see if you have set any error codes in the ECU which can give you a further clue on what is wrong (although intermittent problems do not always set an error code).
    Jul 2011
    Ah yes that's true.
    +1 to BlackVXGTS.
    V8 gearboxes tend to do random things when the tps goes boom. More of a v6 person
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Cashman_309 View Post
    Ah yes that's true.
    +1 to BlackVXGTS.
    It doesnt just effect V8 autos. A faulty TPS will cause the same problems with the V6 autos too. I fixed a VRV6 automatic not too long ago that had really bad shifting problems and was also slipping under hard acceleration, this was being caused by a faulty TPS as it had logged both codes 21 and 22.One new genuine holden TPS later and auto problems fixed.
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by michael9s View Post
    If your going to keep it, spend the bit extra and get it built stronger.
  1. TIme slip
    By VS304exec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2011, 06:10 PM
  2. Clutch Slip
    By white.thunder in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-03-2011, 02:48 PM
  3. Permission Slip
    By Dirbatua in forum Jokes/Humour
    Last Post: 04-04-2010, 08:39 AM
  4. To Slip or Not To Slip...That is the question
    By Spartan119 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2010, 11:21 AM
  5. [NSW] Pink slip
    By maldotcom2 in forum General
    Last Post: 02-01-2010, 01:48 PM
