Results 1 to 3 of 3
Thread: Holden vx manual problem
    VX Executive Manual
    Jan 2012
    dandenong
    Default Holden vx manual problem
    Hi Guys
    this is my first post on this Site and I hope I get some help
    I have a holden Vx manual, It makes this noise from under the car when changing gears (quick shift), If i just take it easy it won't make any noise
    However if i also rev up quickly it makes a loud noise (more like hitting to something)
    i got it checked with mechanics, they are giving me lots of crap, One says gearbox, one says drive shaft, bushes etc etc
    booked with holden for inspection but before that Want the opinion from here
    You only live once, So leave the kings life by having the kings car
    Http://www.melbourne-car-removal.com
    Dirbatua's Avatar
    Dirbatua is offline BORED!
    VX SS Manual, VS Caprice L67, VR Clubsport
    Apr 2003
    S/e Victoria
    the vic section is for things to do with the vic cruises and meets etc only.
    For faults put it under the VX section next time.
    I've moved it there for you this time.
    but probably center bearing or unijoints on the tailshaft if its a metallic clinking noise or could be your diff going if it only happens under heavy load.
    since your in dandenong take it to Hallam Performance in the hallam industrial estate just off hallam road, will cost you alot less then Holden.
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Dirbatua is on the money i think.
    Get the back of the car on jack stands. get under it and with the car in gear try move the tail shaft around, there should be a tiny bit of play but not much, if it clunks or moved excesively then the uni-joints are stuffed. Used tail shafts cost jack all.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. [VIC] Holden Vy Ute MANUAL
    By ERDEM_CIMBOM in forum Vehicles For Sale
    Last Post: 22-05-2010, 12:44 AM
  3. Holden VN Electrical Manual??
    By anarklov3r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2008, 01:07 PM
