as stated i see everyone talking about codes how do i get to see these codes or find them what do i need ? if its a dumb question ignore it
stroking is fine but id rather be blown
Click on the link below and read it thoroughly.
Checking error codes VT/VX
MY RIDE
i found that but where do i get the error codes on the car to see whats wrong do i need a laptop or software? or can just "holden" find them through a diagnosis
You count the number of times the check engine light on the instrument cluster. flashes, it's the orange symbol shape like an engine on the left hand side of the instrument cluster
MY RIDE
oh .... mine stays on all the time:/ need new oxy sensors
v6 or v8 mate?
Real cars don't power the front wheels, they lift them
v6 ecotec how do i get to code check mode ?:/
all good my mechanic mate has a computer and checked for me , cant remember the 3 codes ones about the purge canister :/ one cause i dont have an air box so its missing a sensor or something (says its out of range) and the air temp sensor needs a clean
You put the car into diagnostic mode by bridging terminals 5 and 6 in the diagnostic connector under the dash. Use a paperclip or whatever. Then turn the ignition switch to the ON position and the check engine light will start to flash on and off. You count these flashes to check the codes. Example- 1 flash, or "tens", followed by two quicker flashes "units" or "ones", represents code 12, 1 ten and 2 units. Each error code will be flashed up 3 times.There will be around a three second pause between different codes if more than 1 code is logged. Code 12 will show up before it shows any logged codes,so make sure you let the test go through for at least a minute or two.Code 12 will also flash up again to show that its at the end of the codes. When theres no logged codes to display,it will just continuously flash up code 12 over and over again.
23 Air temperature sensor (voltage high)
32 Air flow sensor (voltage out of range)
WHATEVER THEY MEAN
Just saw that you had it checked. All these problems you mention will effect how the engine runs etc. It wont run properly until all the sensors you mentioned are working correctly. If its got a pod filter fitted instead of the proper airbox,throw it in the bin and fit the proper airbox and filter and connect the air temp sensor up while your at it...If theres nothing else wrong with the car,you will notice a pretty good difference in how the car starts, how it goes, and you will get better fuel economy too.. As I just mentioned, the temperature sensor in the ecotec is in the airbox. The MAF (Mass Air Flow) meter might need cleaning. You can try tapping the MAF (GENTLY) with the handle of a screwdriver whilst the car is idling. If the revs change at all,the MAF is stuffed. The cannister purge solenoid is at the back of the engine on the drivers side. Ive had one of these fail on my VS ecotec and it caused the engine to misfire badly whenever it was started from cold.
trying to find an airbox nowlast loser who owned it did it ... will a new cai from mace or somewhere have the sensor part or is it just a standard box ....and do you know how to fix these ??? 23 Air temperature sensor (voltage high)
32 Air flow sensor (voltage out of range) and purge canister ?
WHATEVER THEY MEAN
MY RIDE
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
LOL i read a link with the same heading but in a different post i thought they were the same untill i clicked your one .
and DLFHUB666 stating i shouldnt be working on cars ? ive rebuilt my old gemini plenty of times without a problem , the VT is a new playground for me gotta start somewhere![]()
I was referring to your question "v6 ecotec how do i get to code check mode ?:/" that was explained fully in the link I gave you.
This is the first paragraph of the PDF attached to the first post in the link.
How to test for fault codes
Firstly locate the diagnosis connector under the steering column. You will now need to bridge terminals 5 (earth) and 6 (diagnosis request) using something like a paper clip, piece of solder, etc. Then switch the ignition to the ON position. Read the codes as follows:
MY RIDE
yeah , thankyou i read to much into it and forgot what i was doing , ive got my error codes and 97 is what confuses me purge canister solinoid , what is it
the carbon canister thing, connected to the fuel tank and vac on tb
cheers capitalgainz can you chuck a pic up cause i look under the hood and see metal , i know what a TB is (throttle body ?) but the little parts ??? im palming my face
Lock/delete please mods
It's not a good idea to delete threads as the information in them could help other.
MY RIDE
might be worth buying a manual to help with the basics
