Sorry about all the threads recently.
So my VX S1 Calais, all the windows work fine except for the front passange side window. I've been told it's the actuator itself and that it needs to be completely replaced, but I've also seen there was an issue with wiring in early model VX's (Mine is 10/00). Could it just be as simple as re-crimping the wired under the switch? Or taking the door apart and re crimping something? Or would it most likely be the actuator?
mine did that as well, every window ecxepct one worked fine. i played around with the switchs for abit, and that didnt work so i got a new regulator, and it fixed it.
Check all your door wiring first. They're prone to breaking.
the regulators are more prone to break then the wiring. my money is on the regulator. and they are so easy to fix.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
^ Would that be to replace it with this?
Yes, that is the regulator. Easy enough to install yourself, if you get stuck, I can write up a how-to (or I think there is one on here).
But I think you can get them a bit cheaper than that if you have a look around, maybe save yourself $20/30.
The New Ride - The Class 2 Shuttle Craft (VE)
Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
Yeah I found one for $60, I'll go with that.
Thanks again for the help, I found a guide for a VY, which I assume would be the same.
yeah you just need to drill out the pop rivets which hold it in, and find some bolts from bunnings that fit the hole and use them instead.
Should I source it from a wreaked car? Wouldn't have any problems yes?
That's easy, I can just go down to miter 10.
Yep just make sure they are pretty close to the right ones, I think you can still order them from Holden though, about $3 each or something.
