Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree2Likes
Thread: vt series 1 air bag light :/
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    Default vt series 1 air bag light :/
    got a vt series 1 the air bag light has come on because some minger (previous owners passenger) ripped the cable to the pre tensioners out of its socket, got to take the car to the local revenue raising joint to clear a minor revenue raising defect, how ever the dash lights up and makes horrid noises as if the worlds going to end because some pelican bumped a wire.
    is there a way to bring up the srs codes and can you reset it by continuously shorting the circuit or do i need to use a tech 2, will the obd 2 scan tools at sprints reset the codes? from what i have heard obd 2 is for vz onwards :?
    any help would be tropo
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Needs a tech2 to clear it. Take it to your nearest mechanic (one who advertises that they do "log book servicing") get them to clear it. If they're chummy they wont charge you a penny, otherwise they might ask for 20-50 bucks. No big deal
    rlg999 is offline Banned
    VU SS
    Aug 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    Remove the warning globe? pfff. As if someone would be stupid enough to do that. Well,then again, when I think about it, theres a hell of a lot of stupid people out there. This is one of the reasons theres so many crappy cars about. The little problems just get covered up or ignored etc,then they all just build up until theres a heap of stuff not working right or whatever.. Some people are just too stupid to spend a bit of money on their car when it needs it, to keep everything in good working order.
    Go and get your car scanned with a scantool,find out why the light came on and get it fixed abd the SRS code cleared..
    Sep 2008
    adelaide
    well brett you kind of just proved how stupid people are....
    i wrote up there i know why it come on, the light appeared as some muppet who previously owned the vehicle some how managed to knock the connector out of the pre tensioner sensor socket...
    not to worry folks, holdens quoted 88 to clear the code, holdens copped a mouth full of it, midas morphett vale quoted 45, southern dyno quoted 30, either way i thought "mhe, its only a minor defect sapol wont check my dash" guess what? they didn't, so all good, i will just buy my own tech 2 and clear codes for people for half of what the retailers are
    Sep 2008
    adelaide
    cash man, its not the money, its the fact people are being charged for someone to turn a machine on, turn your ignition on, then turn your car off, its not time consuming, generally the operator stands around talking shit to you and whilst this may be deemed as "polite"im basically paying some one to talk to me, its not a phone sex chat line, i dont want to talk to anyone but if i dont talk then im an arse hole :/ its a catch 22 really.
    Australians need cheap rates for basic things
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by rlg999 View Post
    Take the dash out n take the globe out!!
    That probably won't work because they often check if it lights up when the ignition is turned on, and when it doesn't they will know that the globe has been removed or doesn't work. At least that is what they did when I last had a rego check. Not to mention the warning tone.
    MY RIDE
    Sep 2008
    adelaide
    yeah dont get me started on the warning chime, although it only happens a few seconds after start up, my passenger is only my misses so i mean if we crash the horrid noise that constantly comes from her might "go away "
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    sending aldl command via say flashtool and laptop can clear srs codes on VT, i think it's FA 56 0A A6, i do have a adx here that should work with tunerpro
    Seanyy's Avatar
    Seanyy is offline "HULK"
    VX II Acclaim
    Jan 2011
    Melbourne, VIC
    Somewhere in the large amount of posts about this exact thing in the VT - VX forum should give you an answer, if you put that tiny bit of effort into doing a search.
    Quote Originally Posted by TrikkBen View Post
    Get a a few pieces of pvc pipe and make your own extractors... That what I did, it came up great and I gained like 40kw from it.
    Quote Originally Posted by f1tzy View Post
    lol umm how do u accidentally sell a car
    Check out my VX II here.
    Comments/compliments/logical abuse welcome .
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by capitalgainz View Post
    Ive lost count of the number of " know it all clowns" who have come to me to get a code cleared or warning light turned off with the tech 1 or tech 2 and theyve been completely wrong about what they assumed to be the cause of the problem.
    Sep 2008
    adelaide
    Quote Originally Posted by Seanyy View Post
    i did actually do this, if you look down the page you will see a few i dug up, these had wrong info, the only way to clear it is with a scan tool or something alike, there is the possibility of putting in another bcm but whether the srs light runs off this is another question i cannot be bother looking into, i will just get a tech2 or buy an aldl cable for the lappy
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    What some people arent aware of is that when the SRS light is illuminated the entire airbag system is disarmed. Airbags do save lives so fixing the problem is definately the best course of action. Removing warning globes is retarded.
    Silver Certified.
    Sep 2008
    adelaide
    agreed, i wouldnt remove the light, its a commodore its not capable of getting up to speeds where airbags dont matter hence why my wrx came with out them , air bags hurt like ####!
  15. #15
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    lol retarded statement on so many levels.
    Silver Certified.
  16. #16
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    and if you paid $10,000 plus for your scan tool would you do it for free?
  17. #17
    VX II CALAIS 5.7 A4
    Dec 2011
    Palmerston, Darwin, NT
    i asked my snap-on dealer to hook his verus up and clear the error codes, all good for now
  18. #18
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by wamboin23 View Post
    That and the fact that DTCs dont tell you the exact issue with the car, they are simply a starting point. The issue could be the wiring harness (open circuit, short to ground, short to voltage), an issue with the module, an issue with the sensor, an issue with the comms network etc etc.
    Only fools clear trouble codes without investigating the cause of the issue and send you on your way unless the cause is obvious. Codes appear for a reason.
    Silver Certified.
  19. #19
    VX II CALAIS 5.7 A4
    Dec 2011
    I look at this way, if the fault reoccurs, then i'll look into it further, sometimes these faults can appear only once, and then once cleared they may not return.
    But if it does return, then i'll investigate it.
  20. #20
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by The1 View Post
    is there anyway i can use my laptop with efliveV4 to clean a vs SRS code?
  21. #21
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jas98 View Post
    You might get an answer on the EFILive forum.
    MY RIDE
  22. #22
    vr v8 calias
    Jul 2011
    victoria
    i had this problem with mine what i did is i took my steering wheel off and behind that there is a round black box which has a wire which is coiled inside mine had snapped off so thats why the light stays on the yellow wire oh do you have a horn? and black or sometimes brown wires as your horn if you dont have a horn then this is your problem go to a wreckker and get another one or pinch apart.
  23. #23
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    VS SRS module isn't on the aldl bus like the VT, so Tech1 will only lookup or clear codes.
  24. #24
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dinnzyvrv8 View Post
    It's called a clock spring and it is about the most common SRS fault.
    MY RIDE
  25. #25
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Another common cause of SRS light is when people shampoo the carpets and wet the connecter at the back of the seat rails.
    Silver Certified.
  1. vt series 2 odometre light
    By r600 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2011, 10:56 PM
  2. engine light on VX series 2 SS
    By hooker in forum Electrical Wiring / Questions
    Last Post: 05-11-2011, 08:40 PM
  3. Alpine V series AMP blinking light...
    By Jesterarts in forum Car Audio
    Last Post: 20-05-2008, 07:49 PM
  4. VN series 2 motor into a VP probs/eng light
    By rod baker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 07:02 PM
  5. Shift light on an 80 series
    By H.I.M666 in forum Electrical Wiring / Questions
    Last Post: 14-01-2006, 12:04 PM
