Ive just had 2 new sway bar links put in, and now im getting squeaking in the front end, again, would it be cause the bolts arent done up tight enough?
spray a bit of WD40 on 'em!
if you had a mechanic install them then they should be fine and i would start looking at something else, radius rod bushes is worn out can get noisy, strut top mounts, z arm bushes...
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
well its the same sound that i heard about 8-9 months ago and it turned out to be the strut top mounts so i had them done, have only done about 40,000kms since then, shouldnt need doing again should they?
