Results 1 to 5 of 5
Thread: block off the PVC valve?
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Default block off the PVC valve?
    Hi there everyone,
    I am in the process of fitting a Powerdyne supercharger to my ecotec, it says in the install instructions to:
    Disconnect PCV breather hose from throttle body. Using plug and cap provided, cap off throttle
    body PCV outlet. Fit new breather hose from breather outlet to supercharger inlet pipe, near
    supercharger. Use same method as in blow off valve hose fitment. Push special PCV fitting into
    hose, lock by tightening nut on hose.
    I have a blow off valve in my kit and am not 100% sure on how to fit it and set up the PVC valve. If anyone has a diagram of how to do it/or knows that would be extremely helpful!
    Thanks
    Glenn
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Need a reply ASAP!!
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Anyone????
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I wish I had my ecotec then I could do up a photo. There is a hose that runs from the bottom of the throttle body to the upper intake manifold, you have to bung off the part on the throttle body and run a pipe from the upper intake manifold to the intake pipe to your supercharger.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Cheers for the reply mate.
  1. Buick valve springs, valve train. need advice
    By GTP 85 in forum V6 Development And Modification
    Last Post: 25-08-2009, 10:22 PM
  2. Valve guides or valve stem rubbers?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2008, 03:57 PM
  3. wtb: vn-vs climate valve solenoid block
    By hakhawk in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2008, 06:51 PM
  4. Valve guides or valve stem rubbers?
    Last Post: 13-09-2007, 12:05 PM
  5. LT1 valve springs and crane valve locks
    By lxhatch in forum Parts And Other Items For Sale
    Last Post: 30-03-2007, 06:50 PM
