Hey so I got a new SS kit and put it on my car and have the SS foglights installed but not connect, I can't find the wiring loom underneath I found some wiring but does not match into the foglight harness it's really pissing me off.
I've inserted the gm foglight switch into my dash already.
Also people have told me to take of the front bumper to find the looms, I just look under the car near the light wiring. Do I really have to take off the front bumper?
Am I overlooking them or are they not there? If so I'll just wire them up.
I have a VX Executive if that helps.
Thanks.
A.MILMO
If you give up its pretty easy to just require them.
Find the dash light wire. Run this as a feed to the switch via a fuse. Then run the wire off the switch through the firewall to a normally closed relay. Connect the relay via a fuse to the positive battery terminal and the other end to your fog lights. Ground them and voila a legally wired fog light setup.
Yeah I'm comfortable in doing that just don't want to if the wirings already there I'd prefer the plug and play but I haven't had a real good look thought I found it then realized foglights didn't plug in don't ask me what that was i have no idea.
But will jack the car up and have a good look tomorrow seems I will have time and hopefully it's there if not I'm just gonna do as you said above.
Was really hoping for confirmation that I didn't have them or I did but either way they will be working by Monday.
Cheers for the info.
A.MILMO
