Results 1 to 5 of 5
Thread: anyone know what this is ?
    troykinsvt's Avatar
    troykinsvt is offline yes i like fibreglassing
    VT
    Oct 2011
    helensvale
    Default anyone know what this is ?
    sorry bout the picture quality
    just going over stuff in the VT and came along this , im stuffed if i know what the guy before me did
    i can see two hoses with radiator fluid in them backed onto each other
    these holes are what i dont get
    do i need them ?
    dose it affect my car?
    Attachment 131923
    stroking is fine but id rather be blown
    VX series 2 S-pack Auto 3.8
    Jul 2010
    i think they might be for the heater core water inlet and outlet.
    easy way to test get the car up to temp and turn the heater on if it comes out hot they are somthing else if it is cold then it is for the heater.
    The old owner could have removed them if it had a leaking heater core, bit of a big job to change that.
    hope this helps
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    yeah they r 4 the heater core the previous owner has by passed the core which im sure doing this can get u a yellow sticker. Brett would probably b right in saying the core was leaking and since its an expensive job 2 get some1 2 do 4 u it was an easy way out solution. if u did it urself tho would only cost around $170 and about 6-7 hours labour.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    ouch 6-7 hours .... might plug the holes so its less noticeable till i can be bothered to fix it
    and im guessing bypassing wont ruin anything .
    thanks guys much appreciated
    wrx884's Avatar
    Mar 2006
    No ur coolent just runs through those lines ( 1 in and 1 out) 2 the heater core and heats it up so u can get heating into ur cabin. so by passing it just means its taking it out of the cooling systems circulation so u would have no heating or demisters which is wat u must have working on ur car.
