Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By SE85VT
Thread: Vt Starting Problem
    Vt commodore v6
    Jan 2012
    Nz
    Default Vt Starting Problem
    hi , ive got a 98 vt commie 3.8 v6 , and sometime when i go to start it you have to put your foot on the accelerator and give it a rev otherwise it cuts out , and sometimes it doesnt crank over at all so you have to turn the key off and turn it back on and try again sometimes its just fine , any suggestions ?
    thanks
    SE85VT is offline LOVE MY VT LOVE AUSTRALIA
    1998 V6 VT BERLINA
    Jan 2012
    Newcastle NSW Australia
    mine had the same problem i read somewhere on here to give the starter moter a tap with a hammer it worked great after that thee gear tilts sideways and when you hit it with the hammer it strightens it worked on mine btw if you dont know where the starter moter its located on the passngers side at the back of the moter go in behind the wheel under the door
    Vt commodore v6
    Jan 2012
    Nz
    Vt commodore v6
    Jan 2012
    Nz
    1998 V6 VT BERLINA
    Jan 2012
    all good mate mine hasnt done it at all since i did that and its been about 4 months
  1. Starting problem
    By dumpedvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2010, 03:08 PM
  2. vr v6 starting problem
    By itsavr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2009, 09:04 PM
  3. VN starting problem
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2009, 07:27 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. VR BT1 V8 Starting Problem
    By vrbt1ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2005, 11:37 PM
Tags for this Thread
