Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By ryan101
Thread: leak found
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default leak found
    I finally found the leak on my wh caprice. It is leaking from the oil sensor located at the back of the engine. Whenever I start the car after it sits for a while, the oil starts leaking from the oil sensor. Today when it started leaking I looked at the oil sensor and it was coming from there. What are my options. Can I clean the old sensor, put some gasket tape and reuse it OR should I buy a new sensor. The car is also giving code for oil sensor. New oil sensor is 37 dollars.
    vx ss
    Jan 2011
    whittlesea
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Yeah!..when those oil pressure sensors leak, they must be replaced. There is no fixing them!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Depends where it is leaking from, if it is from the thread where it screws into the engine then I don't think a new one is necessary. I would remove it, clean it and apply some loctite or something similar to the thread (not thread tape).
    Edit. I just read the rest of you post in which you say it's giving you codes, so definitely replace it. The new one should alreadyhave the stuff on the thread to seal it.
    You will need an extra deep socket to remove it or you can buy a special socket for the job. They are a pain to get at.
    MY RIDE
  1. Found the best oil for my ls1
    By 94CLUBBY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2011, 06:24 AM
  2. vr body leak found
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2011, 09:54 PM
  3. Just found this!! must see
    By Prodrive in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-03-2010, 09:53 AM
  4. Found A Key
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2005, 12:30 AM
  5. hmm, look wha ti found
    By Garth in forum The Pub
    Last Post: 03-08-2004, 11:46 PM
