Results 1 to 7 of 7
Thread: OTR + MAF sensor on a VT SS
    VT SS 5.7 s2
    Oct 2011
    melbourne, western suburbs
    Default OTR + MAF sensor on a VT SS
    I may in the position to score a OTR for my vt SS.
    Now my question is, is it worth installing with a MAF sensor?
    And will it make any real difference to the performance/induction of the car?
    I currently dont have the funds for a MAFLESS tune, plus I don't want to go OVER the top, which is why I'm asking.
    Plus I just want a little but extra poke.
    Any advice would be great, cheers!
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    It wont fit with the maf still there
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT SS 5.7 s2
    Oct 2011
    Sabbath''s Avatar
    Jul 2006
    The OTR's have been designed to be run without a MAF in place. The OTR sits up over the front of the condenser even with the MAF removed.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    You would probably still have issues with the tune due to the air being pushed in rather than sucked. I can see the engine light turning on because of a too lean mix
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    VT SS 5.7 s2
    Oct 2011
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by ls1 tiga View Post
    So you reckon just stay away?
    Unless you're going to do it properly and get it tuned, it wont work.
  1. TPS Sensor Stuck TPS Sensor Low Voltage Indicator
    By tomjones1986 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2011, 06:25 PM
  2. Where is the water temp sensor located on 98 vt ???? (not coolant temp sensor)
    By 13thomo13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 10:19 AM
  3. HSV R8 front left wheel speed sensor - replace just sensor? or need to the whole hub?
    By hsvmaster in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2011, 09:05 AM
  4. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  5. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
