Results 1 to 11 of 11
Thread: Wh gen 3 low on power till 100kmh
    2x 97vts and 2000 wh
    Feb 2011
    Default Wh gen 3 low on power till 100kmh
    Hey everyone i have a weird issue with my wh its sluggish off the line if u try to launch it it splutters but once you hit 100km it has full power ive serviced it with platnum plugs etc new oil im gonna be doing fuel filter this weekend just wondering if any one has had this issue before. thanks in advance for any advice. oh i should add it was fine before i parked it up for 5 months and replaced the box.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Spluttering or missing can often be caused be a faulty spark plug lead.
    MY RIDE
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does it have the same 5 month old fuel in it?
    Visit my Facebook page
    Feb 2011
    nah when i parked it up had 5kms to empty and filled it up with 98 before i started it have been driving it round for a few weeks and still doing it i will also grab some new leads as i haven't changed them yet the weird thing is runs dead smooth till you give it a bit i'm wondering if it may need a re tune as it has twin 2.5 inch exhaust extraters 4.11s and cai
    VT SS S2 A4
    Aug 2005
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    Quote Originally Posted by frankenstein View Post
    Leads tend to do that when they are old
    hj kingswood
    Sep 2011
    Melton
    That sounds like my vs, is it a 6 or 8, if it's a 6, have a gander at my thread about some problem solvers, I changed leads and it ran beautiful for a week then started, now it does it here and there.
    hj kingswood
    Sep 2011
    Melton
    Sorry, just saw gen3 in your op, but have a gander anyway, might be of some sort of help. If it's o2 sensors, just pull them out and give it a run, it'll run better If it is
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Faulty O2 sensors don't usually make it splutter or miss.
    MY RIDE
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Start with the easiest serviceables.
    - Clean MAF sensor. You say you have a CAI which means most likely an oiled pod filter which eventualy means oil on the maf, which leads to incorrect readings, which can cause your spluttering.
    - Inspect plugs. Replace if necessary.
    - Dump a bottle of injector cleaner in with a tank of fuel.
    Feb 2011
    [QUOTE=Cashman_309;2087085]Start with the easiest serviceables.
    - Dump a bottle of injector cleaner in with a tank of fuel.[/QUOTE
    i will be changeing the leads on the weekend hopefully as long as i get time already changed plugs and the cai is just a big mouth induction through the standard box whitch im runing a factory paper type air cleaner. thanks for the suggestions i will try them all to get it going well again.
  1. 0-100kmh Times
    By abg in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-01-2011, 03:15 PM
  2. Help! Slight thumping noise when cruising 50-100kmh VX Lumina. Any thoughts?
    By GlennHardie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2010, 04:45 PM
  3. 3rd Gear Till 70
    By Mungus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2006, 06:14 PM
  4. vs 0-100kmh times
    By dan87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 08:31 PM
