Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By HoZy
Thread: Sensor thing at front of motor, engine cut out
    NeddyBear's Avatar
    NeddyBear is offline Rockabilly Rules
    2002 VX Aclaim S2 Commodore
    May 2011
    Emerald Qld
    Default Sensor thing at front of motor, engine cut out
    I was driving along and the engine just cut out, luckily only 1 klm from home then after towing it home I've checked all the fuses, relays and everything seemed ok.
    I was then nosing around the front of the engine and I see a sensor thing with only 1 wire holding it on so I'm wondering what this sensor would control and would it stop it from starting.
    2002 VX Acclaim S2 Commodore sedan
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Looks like that is either the cam position sensor plug or crank angle sensor plug... An yes, Either would stop it from starting.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vl
    Apr 2011
    brisbane
    NeddyBear's Avatar
    May 2011
    Emerald Qld
    Thanks Guys, I'll see the mechanic at work today and see if its possible to reconnect the wires or maybe a new one would be a better option.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    At the very least, a new plug will be needed.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    NeddyBear's Avatar
    May 2011
    Emerald Qld
    Today I took the sensor plug to our Holden dealer and they tell me its the oil temp sensor and they no longer sell any of the sensors or plugs for the VX and they wanted to sell me a wiring harness.
    Repco and Autopro doesn't have a listing for the oil one but do sell the cam one as a complete unit so I went over to our wreckers and for $2.00 I have a sensor plug with good wiring
    so I'll join and solder it together and fit the heat shrink tubing.
    Would not having the temp sendor connected stop the engine from starting, if not it looks like I'll have to get the tilt tray truck to take it to a mechanic.
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    NeddyBear's Avatar
    May 2011
    Emerald Qld
    Conneted it all up and fitted a new battery and she fired first thing, ran for 10 seconds stopped, cranked it for a minute and then she ran again for 20 seconds and then no more.
    I've been able to get it booked in at our Holden service centre next Friday and will have it trucked in on a tilt tray for $90.00
    commodore VT
    Mar 2012
    I may have the same problem!!! While Im driving my engine light comes on when my car cuts out would anyone have any idea what it could be.?
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by j.rennef View Post
    Crank angle sensor bud
    greasemonkey24 is offline Donating Member
    vt s pac 3.8
    Jan 2012
    armadale
    hahaha WRONG its the oil pressure swith the crank and cam sensors have 4 wires this has only one as if u follow it will go to the knock sensor and earth off from there
  1. Weird buoy thing near left front wheel?
    By frogsta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2012, 07:01 PM
  2. HSV R8 front left wheel speed sensor - replace just sensor? or need to the whole hub?
    By hsvmaster in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2011, 09:05 AM
  3. Out of curiosity... Black sensor looking thing above rear view mirror.
    By martinfrench in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-01-2011, 04:38 PM
  4. Is there such thing as a manual v6 motor
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2009, 07:13 PM
  5. metal thing that holds on front bumper needed please help!!
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 10:12 PM
