Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By scott-95
Thread: Brought Seats with side airbags. my car didnt come with them. should i remove them
    Vx Equipe S2
    Apr 2010
    Default Brought Seats with side airbags. my car didnt come with them. should i remove them
    I brought some vz sv6 seat for my vx. the seats have side airbags in them but my cars old seat didnt have them. should i remove them as the plug is not connect to anything? or should i leave them in. and they shouldnt randomly deploy on me as hey are not connected.
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    They will not deploy if not plugged in.. if you try plug them in via say the steering wheels one they will proably go boom and you can take them out if you wish but no point..
    VY executive
    Oct 2008
    I had the same issue when i installed vz calais seats jn my vy. I had the airbags earthed so they wouldnt build any static, as this is what causes them to randomly deploy.
    Vx Equipe S2
    Apr 2010
    VY executive
    Oct 2008
    I had Greg from ASR audio earth the seats, as I already had him running wires for the controls on the Calais passenger seat controls. Sorry I cant provide much info, I might have a look and see If I can spot the earths, IF so ill put a photo up.
    Vx Equipe S2
    Apr 2010
    doesnt matter to much. it looks like the airbags are bolted to a metal plate in the seat, which as being part of the seats metal frame would earth the airbag out
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    You don't have the 4 airbag modual so there won't be the option to connect them.
    You could maybe ad that and use the 4 airbags. I'm 99% sure all you will need is the modual under the centre console.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Vx Equipe S2
    Apr 2010
    there is no connection on the car side. i can run a passenger airbag as the wiring is there for it. but im not worried about conecting them i just wanna know forsure that having them just disconnected wont cause them to deploy. because to remove them from the seat wont be an easy job :/
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    It takes a hell of a crash to set them off anyway. You really can't guarantee they will never shoot off on you, with that much force built up airbags can pop with age. Its like a disclaimer - this could happen we then don't take responsibility if it may deploy for reasons set above etc. It's like that. But chances of an airbag deploying when not connected especially to power of anytype are close to zero. Don't worry to much about them enjoy the comfort.
    Vx Equipe S2
    Apr 2010
    True. they aren't connected to anything. they are only from a 05 sv6 so not too old. i've never ever seen the side airbags deployed in a vt to vz commodore even when hit in the side. anyway if i remove them ill need to build something to fill its space like on the other side has a hard form support. also i've airbags stored in the shed which haven't deployed soo yea. and btw i asked holden today and they well the guy i spoke to said rip them out :/ as there was cases where they would come loose inside the seat not ground and deploy. argh its a pain to remove them and its a pain thinking they would deploy. if im 99
    % sure they wont deploy i can leave them alone and stop breaking those dam clips
    VY SS
    May 2011
    Auckland
    Guy from Holden is covering his ass.
    How would they go off without electrical connection?
    From Wikipedia
    Quote Originally Posted by Wikipedia
    The electric match, which consists of an electrical conductor wrapped in a combustible material, activates with a current pulse between 1 to 3 amperes in less than 2 milliseconds. When the conductor becomes hot enough, it ignites the combustible material, which initiates the gas generator. In a seat belt pre-tensioner, this hot gas is used to drive a piston that pulls the slack out of the seat belt. In an airbag, the initiator is used to ignite solid propellant inside the airbag inflator
    You won't get 1mA from static
    VX SS 5.7L
    Dec 2011
    Sideneee
    Yeh they wont deploy.
    They need a to be charged, with either a steady connection or a residual amount of power (up to 10mins from being discconnect from loom) to be able to deploy, otherwise you be fine.
    VX SS -  Monaro Themed - K&N Panel Filter, SS Inductions - (engine mods unknown) Mafless to be done
    2.5" Exhaust, BSA 291 Chrome 19" wheels, KYB Shocks, Feroda Thermaquiet Pads, Slotted Rotors
    Kenwood Head Unit, Clarion 6.5" Splits up front (soon), Clarion 6x9 Rears (soon)
    Build Thread - EBAY Listings - Selling. Please check
    Vx Equipe S2
    Apr 2010
    ok what i've done is checked if the bolts holding the airbag are tight and won't come loose and aslo check how well they are earthing though the seats. turns out its super strong as my muilt meter read 0.05 when measured to the door switchs earth. thanks for the help guys
  1. [VIC] **FS New VZ side airbags
    By -scyth- in forum Parts And Other Items For Sale
    Last Post: 08-02-2009, 05:34 PM
  2. Side / curtain airbags and baby seats
    By dominicburton in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-01-2009, 10:24 PM
  3. remove srs - take out airbags?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2008, 09:04 PM
  4. seats and airbags
    By SthEastCustoms in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2008, 04:49 PM
  5. Is it legal to remove airbags ?
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2005, 11:55 PM
Tags for this Thread
