Results 1 to 7 of 7
Thread: ignition barrel or switch? starter motor?
    98 VT HBD
    Aug 2009
    Default ignition barrel or switch? starter motor?
    Hi guys
    Hubby just went out to start the car. Started fine, but there's a loud noise which sounds very much like the starter motor if you hold the key in the start position. Noise didn't go away while driving. Stops when the car is turned off. Could it be the ignition barrel or switch not disengaging the starter?
    Thanks.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could possibly be the starter gear not disengaging. The shaft gets a build up of crap on it and the small gear sticks. Pull the starter out and clean it up but don't put any grease on it, use dry lube.
    Or look at the key when it has started to see if it springs back to the "on" position. If not, then it will be in the switch.
    Visit my Facebook page
    98 VT HBD
    Aug 2009
    Just took it to the Auto Electrician. Apparently the starter motor is 'meshed'.
    VY SS
    Jun 2006
    Albany
    Quote Originally Posted by Melissa View Post
    Hi guys
    Thanks.
    how long did he drive it for?
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    I had the same problem with mine. So i pulled it apart and cleaned it all up with petrol and re greased it and put it back together. Its been great ever since. Not a hard job. I didnt have a second pair of hands tho.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT I Acclaim Wagon
    Sep 2011
    Pakenham, Victoria
    98 VT HBD
    Aug 2009
    We replaced the starter yesterday. The drive gear (think that's what it's called??) was stuck out. The new starter sounds fantastic.
  1. Removing key from ignition switch - have to push barrel.
    By Circlotron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2011, 12:14 PM
  2. Starter motor keeps clicking over when ignition off
    By bang_chong in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-05-2010, 09:13 PM
  3. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  4. VT Starter Motor / Ignition Problems
    By rensvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 02:39 PM
  5. Ignition switch no longer triggering starter relay - what's broken?
    By synoptica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 01:58 PM
