Results 1 to 3 of 3
Thread: trans not changing gear
    vt wagon
    Jan 2012
    sa
    Default trans not changing gear
    my vt is stuck in 2nd gear takes off in 2nd and stays in 2nd my vr had the exact same thing happen i found out that the wire that plugs into the trans had worn through on the gear box crossmember shorting it out and blowing the fuse making the trans go into a limp home mode but the wiring on the vt has protective cover on it any ideas on what it could be.
    Toyota Lexcen (VP Commodore) wagon
    Dec 2010
    Australia
    Could be a dodgy connection on the plug or a wire that has, through movement, broken off the back of the plug or somewhere else in that circuit.
    Get your hands on some contact cleaner, take the plug out and give it, and where it connects into the gearbox, a good blast. I don't recommend using anything else to clean it as contact cleaner is specially made so it dries REALLY fast so as not to leave moisture on the pins. And if you can, pull the protective cover back near the plug and see if any wires are loose or broken off. If so, re-solder them and see what happens.
    Or, if you don't want to take the chance soldering it yourself, send it to an auto electrician to get it done.
    Hope this helps.
    Old cars, are they really worth all the problems and screw ups?.....yep!
    vt wagon
    Jan 2012
    sa
    i will clean the plug and check the wires. thanks mate
  1. gear changing
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 10:17 PM
  2. Changing Trans Cooler???
    By RedGoesFaster97VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2006, 03:14 AM
  3. auto trans fluid changing
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2006, 05:16 PM
  4. trans holding gear
    By flip1906 in forum V6 Development And Modification
    Last Post: 21-12-2005, 06:17 PM
  5. changing to manual trans.. again.. please look
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 12:59 PM
