hey guys quick question, what size is a VT series 1 sway bar mount bush in thickness or girth (lol) size in MM.
and do the link pins need to come off to install them, or do nolathane mounts have a slit in them which you can slide over the sway bar.
cheers, in the middle of changing all my bushes.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
Link pins must come off.
Sway bar bushes have a slit.
STABILISER BAR DETAILS
MODELS - mm - I.D. CODE
- V6 ENGINE - SEDAN MODELS w STANDARD SUSPENSION - 26.0 GE
- V6 ENGINE - SEDAN MODELS w FE2 SUSPENSION - 26.0 GE
- V6 ENGINE - S/WAGON MODELS w STANDARD SUSPENSION - 26.0 GE
- V8 ENGINE - SEDAN MODELS w STANDARD SUSPENSION - 25.0 GF
- V8 ENGINE - SEDAN MODELS w FE2 SUSPENSION - 25.0 GF
- V8 ENGINE - S/WAGON MODELS w STANDARD SUSPENSION - 25.0 GF
- V6 and V6 S/C ENGINE‘S’ MODELS - 26.0 GE
- V8 ENGINE - ‘SS’ MODELS - 26.0 GE
thanks mate, so if they have a slit, why do the link pins need to come off if you dont mind me asking? is it jsut for extra movement through out the sway bar?
AFAIK they have a slit like the rear sway bar D bushes.
All this talk of girth and slits.. oooh weeee
hmm tad confused here, do the front sway bar bushes have slits or no lol? because in this "how to" it looks like he does and it doesnt say or explain you need to take off the link pins to get these onto the sway bar.
How to change front sway bar mounting bushes
Yep the sway bar mount bushes should have a slit in them, not sure as to whether you have to take off link pins when changing or not as when I did mine I was changing the link pins anyway so had them off.
You could get away with loosening the lower link pin mount onto sway bar so you can get a bit of play in the bar, enough to slip the new bushes on with?
yeah might just take off the link pins and quit being lazy.
