Results 1 to 8 of 8
Thread: VT whine
    1992 VP Executive
    Jul 2009
    Default VT whine
    My 98 VT Berlina has a bit if a whine when I'm doing 60-70ish and upwards.
    The sound comes from the rear - someone told me it's probably the diff and suggested I check the oil
    Oil levels seem fine - is it worth draining and changing the oil? If its not the oil, will I need to replace the diff?
    Cheers.
    1992 VP Executive
    Jul 2009
    Tuned VX SS
    Jun 2010
    A better quality/thicker oil CAN reduce diff whine. Ask you mechanic what he would recommend.
    It may not do the job, but it's worth a shot before getting drastic.
    vx custom 600RR
    Oct 2010
    i have that in my VX SI i believe it has something to do with the park brake shoes and there was a fix on the VX SII a spring was added ???
    it is annoying in an otherwise quite car
    dumped vk 202 efi calais mok-up.
    Jan 2012
    berri s,a
    VT SS 5.7
    Mar 2005
    Goulburn
    same problem with my old girls car. was the diff bearings. tryed diffrent oils but in the end replace the diff pretty easy job really
    Real cars don't power the front wheels, they lift them
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by pablo View Post
    Sounds like you have my missus sitting in the back seat!
    Don't let ur misses read that, even if it's true!
    I vote diff, does the sound change when rounding corners?
  1. VZ SV6 Whine
    By MiKExAUS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-11-2011, 08:25 AM
  2. L67 blower whine
    By vnrockit in forum V6 Development And Modification
    Last Post: 17-06-2010, 04:49 PM
  3. tranny whine
    By K9UTE in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-06-2010, 08:14 PM
  4. whine noise on vu
    By zaidan69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2009, 10:31 PM
  5. VN-VP whine
    By GreendragonDMX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2008, 12:58 AM
