Results 1 to 5 of 5
Thread: Cold start
    vt calais supercharged v6
    Jan 2012
    Default Cold start
    When i start my calais when it is cold it does not want to idle properly it sounds like the automatic choke doesn't work (if there is one lol) i have recently replaced plugs and leads but its still doing it.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It doesn't have a choke, it has and idle air control vale (IAC) and it could probably do with a clean.
    MY RIDE
    Jan 2012
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Betsy View Post
    where is the idle air control vale and how do i clean it?
    It is on the throttle body and it looks like the image below, except the pointy part won't be visible. Remove it from throttle body and clean it with some petrol. While your at it you could clean the inside of the throttle body with throttle body cleaner, it should make a bit of a difference to how it runs. The throttle body is the thing that the accelerator cable connects to and it has a large tube which goes to the air box.
    MY RIDE
    Jan 2012
    Thanks heaps for that...
  1. [LS2] Cold Start Stalling
    By Jesterarts in forum LSx Development and Modification
    Last Post: 22-06-2011, 08:22 AM
  2. Cold Start
    By BennyMac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2011, 11:21 PM
  3. Cold start splutter
    By XStatic64 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2011, 06:24 PM
  4. Cold Start issues
    By mmvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2010, 07:39 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
