Results 1 to 7 of 7
Thread: VX Hsv Springs in v6.
    Vx Equipe S2
    Apr 2010
    Default VX Hsv Springs in v6.
    This is probly a dumb question but i've got some hsv springs from a vx r8. the rear springs are the same as fe2 with EM on the tag which according to the holden service manual is v6 v8 fe2 rear springs so thats not a problem. my problem is I dont not know wat the code HT is HJ i think is front fe2 for both engines v6 and v8. which in saying that holden in the vx only made one set of fe2 front springs for the v6 and v8. so im guessing HT is a hsv spring but would be almost the same as the fe2 spring. so if i fit them the car should sit the same as fe2?
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    they will fit but i think they will sit a bit higher because of the weight of the 8 compared to the 6
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    Vx Equipe S2
    Apr 2010
    ok i fitted them yes it does sit higher by about 5 mm then my dads gts which has the same HT tagged springs in it. its still lower then standard (fe1) , looks sick and rides and handles better. So i would say its worth doing it u get the hsv springs and shocks cheap but ur car may sit different as most commodores will sit different. for example my bros vx exec on standard springs sits the same as the vx gts does when measured from the same point on the body
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    less than 10kg weight difference between v6 and v8
    ========My Statesman 20's Mafless and 3.9's========
    Vx Equipe S2
    Apr 2010
    Still like to know what the Code HT stands for. like eg HJ is code for FE2
  1. Replies: 16
    Last Post: 25-10-2011, 03:22 PM
  2. [NSW] WTB VU front v8 struts/springs and rear springs standard height
    By dreammist in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2010, 11:55 AM
  3. King Springs low front springs, are they lower then FE2?... oh and the rears..
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 07:32 PM
  4. [QLD] swap Solid axle springs for IRS springs for the rear - Goodna
    By Gus The Snail in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 07:59 PM
  5. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
