So last night I was coming home from work and I went to do a three point turn but as I reversed out, I seemed to have driven over a little heavy metal outcrop that someone had stuck in their lawn that I couldn't see. Well anyways, as I drove over it, it got caught underneath my bumper and pierced this hose that runs along behind my lower bumper. I found out the liquid was green and was gushing out so I came to the conclusion that it was coolant fluid. How expensive will it be to get that hose replaced or should I get a bypass if that's possible? And is it easy to fix it myself?
Here's a photo of the burst coolant hose (this is underneath my car and it runs against the underside of my bumper).
Okay, but this happened underneath my car.. So anything above that surely can't be damaged at all. I saw a green liquid gush out because of this and it seems to have come from that hose and I'm pretty sure that's coolant. If that's meant to have electrical wiring in that hose then why would there be coolant coming from there? It's the only damage I could find
do you mean the thick black hose in the top there, or the skinny one running along the bottom?
the thick one up top in your photo is coolant.
the lower one running accross the bumper, is wiring for fog lights etc.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
The hose in the picture is definitely not a coolant hose. Im with munz in thinking you have bust the core itself not the hose.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Ahhh okay then. Sorry I'm a bit enexperienced about this all, but is the core inside that thin black hose running along the bumper? If I broke the core, how does that mean my coolant is leaking?
Inexperienced* lol
your heater core? is under your dash inside the car, take the car to a mechanic and get a pressure test to reveal some leaks.
I might be wrong but is there no hose clamp on that hose??
My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
I just put my car in for a service and I should be getting it back this afternoon. I'll attach this picture as well to show you guys that it has been leaking from about 4 of these spots on the other side of that metal bar that the black hose runs along. It's leaking coolant fluid.
That black hose aint leaking coolant mate it contains wires no liquid at all yes your car is leaking coolant from somewere but it is above the conduit you think is a pipe as you know water will run down so if the radiator has a hole in the front of it it will leak down the front of it and run out the bottom out.
And yes it has a clamp on the rad hose its just hard to see as it the stupid twin wire one.
LMFAO Dude if you think that is a coolant hose I suggest you take the car to you local (closest possible so it doesnt overheat) mechanic ASAP, before you #### something up.
If you do drive it, do it with the radiator cap half undone to limit the pressure building up. It will get you a bit further, but keep one eye on the temp gauge
Terrible advise. Don't do this. It will cause the remaining coolant to leak from the top raditor cap which will then coat everything under your bonnet. Radiator caps have inbuilt pressure release valves which help remove air locks and helps deliver coolant to the overflow bottle.
