Hi forum. I searched around and read some great stuff on changing spark plugs. However, when I when I disconnected the leads only the ends were visible and the spark plug socket has nothing to grip to unscrew. I wonder if this is because my car is dual fuel.
I've attached a pic. Any advice on how to remove the spark plugs?
Thanks
you need to take your engine cover off and follow that lead to the other side of the engine and under the other end of the lead is the spark plug.
that is your coil pack.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
That's perfectly normal, that's the connector on your Coil Pack. Spark plug connects to the motor on the side of the cylinder heads, just above and in between the exhaust headers.
I got the spark plugs changed. Thanks for the help. It didn't fix the problem though, but I post that in a new thread. Cheers.
