Results 1 to 6 of 6
Thread: VS motor in Vt - can't start car
    VT Commodore Series 1
    Jan 2012
    Devonport TAS
    Default VS motor in Vt - can't start car
    Hi, we have dropped a vs motor into a vt commodore series 1. Can turn car over but cannot get it to start. Please help! Have replaced crank angle sensor. Taken to mechanics - says voltages check out ok. Getting desperate to get this car going now
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You need to link the BCM and ECU with a TECH 2. It's a security thing.
    MY RIDE
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If the BCM and ECU are still the originals, it shouldn't be a security issue, you need to change a couple of sensors over too, the engines are basically the same, just the VT uses a few different sensors. Put the VT sensors on the VS motor.
    Visit my Facebook page
    Jan 2012
    Devonport TAS
    Hi. The BCM and ECU are still original. We have replace crank angle sensor. Please advise which sensors need replacing please.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I know the coolant temp sensor is in the VS but not in the VT, so the plug for it shouldn't be there. Don't attach anything to the VS sensor.
    vx
    Aug 2011
    sa
    surely the mechanic should have sorted it out.
  1. New motor won't start
    By vtv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 09:14 PM
  2. VLT Start motor on the way out?
    By calais_SC6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-06-2011, 06:50 PM
  3. changed motor & wont start
    By naked racer in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2011, 02:59 PM
  4. Motor turns over but wont start...
    By Stellaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 09:36 PM
  5. vn motor won't start
    By js1978 in forum Electrical Wiring / Questions
    Last Post: 31-08-2005, 09:26 PM
