Hi all. I have a VX Berlina 2000 model and recently flushed the radiator system because of a Oil like substance in the dipstick hole (Is that what you call the yellow thing that shows the level of coolent?)
Only thing is, it has come back after 2 weeks and is worse then ever. I will attach a photo to show you what exacly im talking about. Hope someone can help :-)
Picture was taken on my shitty nokia. Sorry for the quality
Its defenitly oil of some description as its not lumpy or grainy. Its got a oily consistency.
Oil in radiator....motor is on the way out.
More specific. LOL,
possible: head/head gasket.
:intake manifold gasket, which from what I know is more common than head gasket, especially if you havn't overheated the engine.
Also may be a burst transmission cooler line inside radiator which is a reddish coloured oil.
Its either the Inlet gaskets or a Leak with the transmission cooler. Check your oil, If its not milky. Get it pressure tested, if thats fine, either inlet gaskets or radiator. My VR was the inlet Gaskets.
Id say its the inlet manifold gaskets leaking/blown. A very common problem on these engines once they get a few K's up on the clock..(150,000 k's +). When you replace them ,try to get the metal type gaskets, these will last a lot longer than the standard ones.I think MACE sell the metal type...
