Can anyone help? Is it the same as what you do in a vs? I heard that you can get to the ECU itself and it will have a dial on it. You start the car, turn the dial all the way to the left then all the way to the right and then turn your car off. Next time you drive it it will reset and learn how you drive again.
This question is in relation to my car having developed quite a few misses after me installing a pod filter and a 2.5 cat back with headers.
Disconnecting the battery for a few minutes will reset the ECU but I think you problem might be something else, like a bad spark plug or lead.
MY RIDE
Pull out the yellow engine fuse in the bay for a few minutes
After fitting the pod filter, did you refit the air intake temp sensor?
why remove a cold air intake?
