Results 1 to 10 of 10
Thread: Lowering
    1998 VT Commodore
    Jan 2012
    Heathcote
    Default Lowering
    Probably already covered 1 billion times, but I was wondering if lowering would improve handling at all? 2 inches back and 1 front or something like that, not bothering with power until I have a car which handles and stops well...or would such a small drop not be worth my time/not worth the gains? If there is a thread already covering the n00b questions, feel free to point me in the right direction.
    Cheers.
    EDIT: Stock VT sedan, or as stock as I could imagine
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    People will have a go at me for this, but lowering does not in of itself improve handling. If all you do is change the springs on your car, it will not perform better, if anything - it will be worse.
    You will have to change over virtually the entire suspension to achieve better handling.
    Mike.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    aaronevolution's Avatar
    aaronevolution is online now Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by MikeCuzzy View Post
    Mike.
    Agreed.
    OP, you drive a VT Commodore. It's a boat and will always be one.
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    After going from FE2 stock springs to SL and SSL springs my car turns alot sharper into corners. I have had other mates drive mine after their stock ones and they agree. the steering is better with slightly tighter and lower springs (y) If you do it youll notice, hell id let you drive mine to prove it.
    VX II Executive
    Jan 2011
    Vicotira, Melbourne
    Quote Originally Posted by JSTCOZ View Post
    I agree i noticed it turns a lot sharper into corners with my Ultra lows.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Lowering doesn't improve handling as such, just makes it stiffer so it feels like it corners better.
    Lower it to make it look better, not to handle better.
    Visit my Facebook page
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Mike.
    Good answer.
    As above, simply lowering a car will not improve handling much if at all. It can reduce body roll a bit so there may be a minor improvement, but as a whole the only way to improve the handling of any car is to upgrade the suspension setup as a whole.
    Springs with matches shocks, upgraded bushes and sway bars are required to if you are looking for significan improvements.
    1998 VT Commodore
    Jan 2012
    Heathcote
    Cheers, might as well leave it as it is then until I'm prepared to shell out some more cash to upgrade the whole lot at once.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    But then what is the car? Is it going to be a track car or a daily driver? Why spend $2-$3K on suspension upgrades when you will still have a VT Commodore. It is never going to corner like an F1 car or handle like an SLK Mercedes.
    hj kingswood
    Sep 2011
    Melton
    Prob irrelevant. I dropped my old girl 2 inches, now Kingswoods do handle like boats, with a heavier sway bar up front, doesn't have one up the arse, handled beautiful after, instead of it losing front traction at 80km, it starts losing at 110km, then using a custom one up the arse, it handles better again though tends to want to slide a bit more in the wet. Don't skimp on sway bars, they probably do more in a corner than springs, so in effect, lower centre of gravity, yes will improve, not much, heavier sway bar(s), better shocks if your going more than an inch, and lastly, a set of sticky low profile Tyres on big rims help too, less sidewall flex... But all this minus wheels puts you in the 2k-3k mark.
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. VE-SV6 Lowering
    By Jethrotracey in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-01-2011, 09:45 AM
  3. Lowering VY Ute
    By shadowmaster in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-06-2010, 08:58 PM
  4. lowering
    By AWSUMVB308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-06-2010, 07:25 PM
  5. Lowering VX S pac
    By Peasant in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2007, 07:51 PM
