Results 1 to 5 of 5
Thread: Car stalls on LPG
    VT acclaim S2
    Dec 2011
    Default Car stalls on LPG
    When I switch to LPG the car runs rough, the revs drop and then it stalls. The LPG light doesnt even come on either or the gauge, Its a factory fitted LPG so the fuel gauge is also the LPG gauge when switched over. It also smells slightly of gas under the hood so maybe a leak? I bought the car about 3 months ago with an empty gas tank and have only just put gas in it.
    What might be causing the car to stall.
    SE85VT is offline LOVE MY VT LOVE AUSTRALIA
    1998 V6 VT BERLINA
    Jan 2012
    Newcastle NSW Australia
    It could be that it is not tuned get the car tuned by someone that can do both gas and petrol and the gas smell could be because it it tuned to ritch causing the car to flood try this and it should work nif it dosenot he will tell you whats wrong with it its time i get mine tuned again lol only costs 150- 200 max
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    VT S2 Calais 5.7 A4
    Aug 2005
    More than likely an air leak. Perhaps one of the smaller hoses has been dislodged. Try tracing all the hoses to see if they are all connected. If it is a V6 there is one under air intake on motor that can be easily dislodged. But also take it to gas mechanic if you don't find anything that solves the problem
    1997 VT Commodore Executive V6
    Oct 2011
    whyalla,SA
    check all your fuses as well, usually if its a vacuum leak your gauges and indicators should still work.
  1. help vr stalls sometimes
    By speed__demond in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2009, 05:40 PM
  2. VP V6 Stalls on a hot day
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2008, 11:07 PM
  3. stalls on gas sometimes?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 06:06 PM
  4. Stalls
    By msh_crew in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-10-2005, 10:45 PM
  5. Vp V8 Stalls
    By finarfin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 10:30 PM
